- 2,054
- 59
- 48
- Milford / Michigan
I think i have a brake dragging some on my M105A2. I dont have the 3-3/8" or 3-7/16" socket to pull the hub off to get to the brakes. is it possible to take off the 3/8" nuts that hold the drum on to access the brakes? I tried adjusting them, checked parking brakes incase they were tight, released the air and still the left side wheel does not spin as freely as it should. I looked at the TM's and it appears i can just remove the drum where on the M105A1 it looks like i may not be able to because of the grease shield. I am going to the rausch creek rally this evening and it would be comforting to know i wont have a brake dragging. another thing i could have tried is to leave the brake adjustment loose and drive the truck and trailer to work this morning and see if the excersize frees it up.... but if there is a problem, id rather fix it properly.
so after all that rambling, can i just pull the drum off to check the brakes? if not, what size socket is it....3-3/8" or 3-7/16'?
