M105a2 w/shell
DUECE-COUPE
Scurry. Tx
After a long time and lots of patience, i have successfully bid on a trailer with a shell for my 2012 rig. Since i only want the shell to put in my trailer, the other trailers will be sold or traded to off set transportation costs back to the house. Pictures are available.
DUECE-COUPE
Scurry. Tx
Going to put 14.50x20's on a3 rims on the trailer and get the truck trailer connector fixed. It looks like it will need a cleaning and painted to match the trailer.
BKubu
1,131
Gaithersburg, MD
Beautiful. FYI...those tie down straps are not correct. It is supposed to be bolted directly to the trailer. It is a quick fix. If you want pics, I can send you some of my CBS shelter mounted in my M105A2. You are lucky that I did not see that baby...and that is why guys should not post about auctions. I missed that trailer, but I would definitely have bid had I seen it. Congrats!
DUECE-COUPE
Scurry. Tx
I would love any info you have on the correct mounting procedures. Will be using the ratchet straps for other things. They were just a bonus
jimm1009
70
Louisville, KY
Here is the cover page for the shell.
I'm not sure if you can download it from S.S. resources but you can get it from LOGSA more than likely.
I can e-mail a few pages to you if you need them right away.
jimm1009
Edit: Here is the link on LOGSA. It does not appear to be available on the S.S. Resources section though.
https://www.logsa.army.mil/etms/index.cfm?fuseaction=viewsearchresults
Type the TM number in the line for publication number exactly as it is on the cover page.
The right click on the TM number when it displays it and save to your desktop or your documents, etc. It is much faster than opening and then saving.
1,807
Looks good. Will you share with the masses what it set you back? Also, do you have a source for -A3 rims? I have some 14.5 tires here.
1,807
I've given up on my plans to run 14.5s in the front and 11.00 out back. Now I'd just be happy with 1100 NDTs. I'm trying to move the 14.5s.
