M105A2 Wheel Seals
3,179
Pulled the hub and wheel cylinders off yesterday, YUK, they were full of goo, but cleaned up nicely. The seal was pused out of the hub and looks like it was that way for a while but looks like it doesn't fit the hub too well. Might just be from being out of the hub and crooked. The seal is a National, p/n 6584-s. The p/n out of the TM is 7411429. Is there a way to x the mil # to a CR, Nat'l, just to make sure the one I have is correct? I tried a search, there are lot's of questions about the seals, but no answers. When I get it figured out, I'll post the numbers in the x ref. section.
3,179
OK, after a bit of searching, the NAPA guy found a seal that is great! Installed it and the hub today, ordered 2 new locks today...what a dufus, didn't think of ordering them at the same time as the seals! Here's a few pics, after I get all the parts and p/n's, Iwill post them here and put them in the x ref section. They look different, but they are the correct ID and OD.
Fresno, Ca
Seals
Will,
Do you have the hub that has the cap with 3 screws or the 6 bolts? The 3 screw type should use the same seal as the GMC 211/135, at least that is what I was told.
L.C.
