I'm making some modifications to my M1061 for hauling sawdust, mainly behind my m929A2. I don't want to make it into a dump but I still want a way to offload that is not my back operating a shovel, although bagging it up directly from the trailer is an option. I'm leaning toward a mechanism to push it out the back hydraulically....a moving front wall. Maybe it could help with compacting while loading....planer shavings are very light and fluffy.
I'm adding pockets to the side of the trailer and a 3/8x3 flat for chain connect now. Sides are planned 6'. The back gate will swing at the top and the front....a moving wall.
One of the problems on pulling a 1061 is that it wants to go straight because of the type suspension and long distance between axles. I'm going to lengthen the tongue to gain some leverage AND be able to dump the dump truck while still connected to the trailer. I'm thinking about 10' added.
I could run an aux hydraulic from the truck and would if I used it continually, but the slow speed of a battery unit is okay too, and self contained would let me use the deuce as the tow vehicle.
First I have a question about the M1061 hitch ring and its weld connection. Has anyone removed the ring and left the underlying 1" plate un-damaged? How exactly is that forged steel ring welder to the plate? Does that plate have a 2" hole inside where there is additional heavy weld, in addition to what you see on the outside perimeter. IF it does not have the inside weld, simply cutting off would be easy, but if there is an inside weld, I will have to take more of the plate with the ring. That will be a precision torch job.
Another question is....has anyone seen Isuzu duals on a 1061?
Note the side of my trailer, it's a channel. My finished width is 8'4", whereas a 1061 that has the normal boxed outside would end up over the 8'6" limit.
Please post pictures of modified m1061s here or make construction suggestions for what I post up.
Thanks, Toby
Thanks, Toby
