m106a1 questions
bgeraurd
Yuma/ AZ
m1061a1 questions
I have found an m106a1 trailer about 100 miles from my house that is pretty clean for $1800 and I have a couple questions about them. What size tires do they run? How hard is it to find spare wheels, this one doesn't have a spare and I don't want to leave home without one? Can they be converted to electric brakes? I intend to use it to haul hay behind my 03 dodge 3/4. I like these trailers because they look well built and have the stabilizers at all 4 corners. Any info would be appreciated and some pictures of the suspension and underneath frame rails would be awesome.
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
They are HEAVY. I doubt it will be worth the purchase if you only have a 3/4 ton Dodge to pull it with.
M813rc
3,827
Near Austin, Texas
Are we perhaps talking about the M1061, a flatbed, rather than the M106, which is a water tank trailer?
If so, the M1061 uses 12-16.5 tires.
Cheers
bgeraurd
Yuma/ AZ
No I'm talking about a m106a1. They aren't that heavy at 6k, my 30 foot gooseneck weighs more than that. If I put 6k on a trailer that weighs 6k it won't be bad at all. That's what load assist bags and trailer brakes are for.
juanprado
3,167
Metairie/La (N'awlins)
double check your data tag as the m1061 have the 4 legs on each corner and dual axles and are 6 ton.
There is also another variant 7 ton m1048
If so on a m1061, the tires are hard to find and expensive as not a common size. PM me if they are 12 x 16.5
post pics to help us id for you
gimpyrobb
27,787
779
Cincy Ohio
Sounds like your not sure what your talking about. I did a search for a m106a1 and it came up as an APC.
What you are describing is a m1061.
Warthog
244
OKC, OK
Are you looking at this type of trailer? It is a M1061A1
The pictures above are one that is listed for sale on the web for $1350. It is listed as a M106A1, which is a typo.
Any trailer can be converted to electric brakes if you have enough money. I would thing converting this one would get expensive
gimpyrobb
27,787
779
Cincy Ohio
Just sounds like a lot of time and effort to haul hay. I would think there has to be something civilian that would be more suited.
doghead
4 Star General /Moderator
1,192
NY
They have no tongue weight unloaded.
Towing that with a pickup truck is a very bad idea.
No easy or cheap way to change the brakes either.
bgeraurd
Yuma/ AZ
I am starting to agree with you. I just thought it would be nice to through 60 or 70 bales on and cruise. My gooseneck is more than suited for the job but it's like towing an aircraft carrier. I have a 16 foot car hauler but the last time I put 50 bales on it it looked quite sad. These trailers seem very well made and I just thought it would be a good fit for what I need.
doghead
1,192
NY
You would need to stack pretty high to get 60 bales on one!
doghead
1,192
NY
The deck height is high to start with.
CARNAC
The Envelope Please.
712
College Station, TX
The price is a little high also, especially if not in cherry shape but you already said no spare. I paid $700 for mine from a private buy with vg tires to include spare and everything working.
I like it for towing behind a deuce or 5 ton but you would be a less than bright person for towing one behind a standard pickup truck.
1,824
The looks of the trailer are deceiving. I towed an empty one home with a CUCV and it was super low in the front.
