M1078 A0 change inner door handle
Plasa
322
Italy
Hello forum.
I remade the inner door part and now the inner door handle won't fit because they are too short. On a previous post someone wrote that Volvo door handle will fit. Does someone change the inner door handles and know some type that will fit?
Thanks a lot and regards from Italy!
Christian
DiverDarrell
24
Port orchard, WA
without knowing how thick the wood is that you used, makes this a hard question to answer. I’ll be working late today, hopefully tomorrow I can look at the difference between the Volvo and stock handles as I have both. One way to solve this is to weld up an aluminum handle and have pipe where it attaches to the splines. Then cast the splines in using fiber reinforced epoxy.
Plasa
322
Italy
Hello.
The wood is not very thick, about 3,2mm woos and 5mm foam that can compressed. The original handles have sharp edges and I fear they will cut leater...
Welding a pipe on the alu handle can be a solution, I will think about it!
Thank you
Christian
Third From Texas
6,498
Corpus Christi Texas
Not sure of the degree you are looking to keep things OEM/mil-spec, but I was looking at a video of a rig the other day that had larger/square door latches (like those found on external ambulance closet doors). Someone commented today that those were used on late model LMTVs and not some sort of conversion.
It leads me to believe that (as with most vehicles) you can fab up anything and make it work. Those big, heavy ambulance box latches sure as **** wouldn't be braking on someone...
Awesomeness
1,518
Orlando, FL
The door handles are a standard 7/16" round shaft with 16 splines. You can find a lot of handles that will fit it, but I'm not sure how many will have a protruding nose that will fit down inside the door panel.
I don't plan to use them, but I bought these out of curiosity to see if they fit, and they did. https://smile.amazon.com/gp/product/B00OPZ49YO/
Plasa
322
Italy
OK. Thank you very much for your help! I will try the thin plastic ring and also the alu handles from online market...
Thanks a lot from Italy!
coachgeo
3,461
North of Cincy OH
below thread has good info on the alternate ones linked. there is now another very similar than one linked above on same site that looks to have a little bit more metal (round holes instead of slots) thus may be stronger. few bucks more each. I will be using ones previously linked for door handle too... removable nobs on these makes them a door handle... so you end up with it all matching. Though going to electric windows.... I do hope to find a way to be able to slip crank on in case electric ones goes down. Got other priorities first though.
https://www.steelsoldiers.com/showt...-handle-and-window-crank-(NOT-military-match)
NV555
Ely and Vegas Nevada
I would not buy these. Poor design bad fit and not long before they wobble off or become stripped. Waste of money!
coachgeo
3,461
North of Cincy OH
can't disagree...... will report back when I finally get them installed. Based on your report and another I do plan to:
1. glue the adapter inside the handle as well as use locktight on the set screw
2. lube the splines and surrounding area with Petroleum Jelly then put small amount of JB weld or similar epoxy in the female then push it on... to really create a tight proper fit. Once dry. Petroleum Jelly should allow for removal. Clean up the jelly then reinstall.
