M1078 Air/Hydraulic Pump Electric Replacement
Ronmar
8,189
Port angeles wa
Well it was sure nice of them to fill in all the performance data... Looks like Stone became SPX and that model info is not listed on their website... Since the pump is inside the reservoir there is probably no pump displacement info easily available either without removing the can.
The smallest pump they now make is 0.8CC/REV which would probably yield 0.5-0.6GPM at 1500 PSI which would be ideal IMO and would provide a 20 second or so cab tilt with the least draw from the power system. Since they have always made a modular product, you might be able to get a 24V motor for that one. they have lots of distributors around...
charlesrg
74
Nj
Ohiobenz
274
Seville, OH
Reviving this thread as I could not find the Part number for the Electric + Manual pump that @Reworked LMTV got.
From the info @Ronmar posted the model that could work would be thePower Packer 24V 2100-2400 psi EP25044300 i
Got it from:
It costs about $895.
Anyone has an alternative that costs less ?
While I understand the desire for a manual backup, it's much more cost effective to carry a spare pump motor if failure is a concern.
I really love my 12v electric pump setup. It would take a dead battery bank to get you to a point of not being able to tilt the cab. It is way more dependable than the air/oil system. I have tilted my cab part way and it just sits there for days on end.
charlesrg
74
Nj
What's the model you've got ?
Reworked LMTV
Expedition Campers Limited, LLC
1,544
1,203
TN
Got it from:
There are LOTS of alternatives. Mine was from Ebay and used. You can also get replacement motors all over.
coachgeo
3,495
North of Cincy OH
why cant you keep the manual pump??? would not two 3way valves to redirect flow to/from manual pump and electric pump work?
something like
or some other plumbing means like quick disconnects and just move hoses to manual or electric
Ronmar
8,189
Port angeles wa
If you are keeping the original manifold, you don’t need anything, in fact you only need a single acting pump with a pressure relief, a check valve and a return port to replace the AOP.
Now if you are getting rid of the manifold valve you will need a valve assembly or combination of valves to replace it if you are keeping cab tilt, tire crane and suspension compression.
If going manual only I would replace the hand pump with a different one made by the same manufacturer that has a reversing valve built into it(Broke Overland over on utube did this). With that hand pump, you would only need a manual 2way diverter(inexpensive valve) to get 2 functions like cab tilt and tire crane. You could do 3 functions with 2 diverter valves...
I have thought about going manual only cab tilt like BrokeO did, and relocating the pump up into the front bumper:) haven’t decided which way I will go yet.. I have a pair of large hydraulic trim pumps I have been meaning to experiment with but haven’t gotten to it. Just started moving into our new house yesterday after final inspect was signed off...
Third From Texas
6,663
Corpus Christi Texas
This might be an option but I don't know the specs offhand. They are designed to lift the rear armored door on an MRAP so I assume it can handle the cab.
Bonus: It has a manual backup built-in.
They've been flowing off GP for weeks and I think it would work. Some scalper looks to be hoarding them all as usual, though. Maybe a few here looking could do a group bid on a set (they are only being sold four at a time). I pondered a set for another project, but went a different direction.
See : Navistar 3114386C91 Hydraulic Pump on GP
charlesrg
74
Nj
Interesting it seems to be 48V.
Picture taken from: https://www.govplanet.com/for-sale/...ydraulic+Pump+on+GP&rr=0.2&hitprm=&pnLink=yes
I would take if it was 24V.
Third From Texas
6,663
Ohiobenz
274
Seville, OH
Yep
Still, you can get a stepdown off Amazon for under $50. I'm sure there is one out there than can handle the amps.
But then you still have a military unicorn with hard to find replacement parts when it breaks down, vs the electric one I used where every RV repair shop has parts....
Ohiobenz
274
Seville, OH
Did you have to I stall flow control valves? If so what valves did you use?
This is a prototype of a unit I had built to my specs for both cab tilt and tire carrier.
Dual valves, no flow controls needed, fits in the toolbox behind the cab, dual pendant control.
12vdc
I'm in the process of developing a mounting bracket for it. If anyone is interested I'll be taking pre-order deposits as soon as I finish testing and make needed modifications for final production.
