M1078 Leaf Spring bushings
markgjsquires
Prattsburgh, NY
After a trip with some excessive vibration I went through all my grease points and noticed practically all the rubber bushings are gone. I was able to order the bushings for the rear sway bar through gentleman on here but I’ve been trying to source replacements for the leaf spring to shackle mounts and have been having nil for luck just wanted to try to reach out if anyone’s had the same issue and what possible solutions are. I’m hoping I don’t have to remove the leaf springs and get new ones pressed in but if that’s what it is then I’ll get the 8 foot pry bar out and get ready to run through some swear words. I’ve also noticed some replacement ones have 4 leaves but all mine are 3. Perhaps since it’s a 1996 that’s what they had as opposed to the newer ones. Any help would be greatly appreciated.
Thanks.
MrMikey4026
417
Eatonville Washington
I think you will find they have bronze bushings.
They don't wear out often, and they are greaseable.
So, I don't really think that is you issue.
Any truck spring shop can rebush them for you.
Swaybar bushings seem to get lost, stolen or just fall apart.
ramdough
1,731
Austin, Texas
[mention]Awesomeness [/mention] sells new greaseable bushings. Just search for them.
coachgeo
3,546
North of Cincy OH
he sells sway bar bushings... not leaf spring bushings......... OP already stated he replaced sway bar bushings (likely from Awesomeness)... but I get it.... its easy to get lost in a thread and forget what was said to have been done already.
