KellyC
- 0
- 1
- prineville Or.
Just got my first MV a 1998 M1078.
Like most I bought it online and one of the gov sites.
The machine was as advertised and missing some components so it is a non runner.
As far as I can tell missing is the entire dash panel, all fuses and relays, Alternator, and door handles.
So my thoughts are do the minimum to see if its starts and at least moves. So far we have hooked it up to air and brakes and air over Hydro. system appear to work correctly. We also hot wired the starter and the engine at least turns over.
Can anyone tell me a short cut to just start the engine and confirm it runs??? I have built a lot of hotrods and such and it seams to me that with the missing items and the overly complicated wiring why could't I just put in a 12v starter and Alt. and install something like a Painless wiring harness? It seams to me for civy use the wiring could be a lot simpler, aside from the trans control which I assume is stand alone like on motor homes. Thoughts? Comments? And yes I have started dissecting the TM just looking to see if anyone has tried this.
