MarkM
- 1,151
- 2,110
- 113
- WOBURN. MA.
Here's what I recommend for charging:
1) search eBay for "24V PulseTech Battery Solar Pulse Charger w/Mounting Kit"
or beter yet
2) charge your dual batteries via shore power (I prefer this over solar because the vampires come at night when the sun is down)
But as I'm sure someone has mentioned, the 100a alt in the A0 and A1 trucks is anemic as ****. The 12v side is only 50a and so much is pulling on the 12v side with just the OEM stuff (add more lights. radios, etc and it just gets worse). S&S terribly under-sized the alt (or oversaized the battery bank, depending on your perspective).
Factor in the vampiric drain on the 12v side, and....truck no go.
But if you insist on quad batteries, get two of the NOCO's listed above.
I second the solargizer unit as I've had mine for five years and have zero issues with batteries. If you use a cutoff switch get a good one.
Mark
