I got called in to try to help a small local volunteer fire dept get their recently acquired M1078A1 working. Seems someone replaced the batteries but had the two inner batteries placed in reversed, so power cables were hooked up all wrong. Got that fixed. Now have proper voltages from master battery cut off switch to some sort of dual solenoid assembly but there is no power to any of the electronics inside of the truck. Have turned on manual battery disconnect switch on lower left side of instrument panel and the manual battery disconnect switch that drive the solenoid assembly. Nothing. Anyone have recommendations as to where to go from here.
Note, at one time I was able to find a SS thread on how hard it is to get the manuals for the A1, but can't seem to find it now. The A0 manual is useless for electrical on the A1.
if batteries are wired wrong the A1 version of the reverse polarity box (I forget its name/acronym) will shut things off..... which is what it is meant to do. It is behind spare tire. Not sure if there is a reset on it.. or if you have to disconnect all lines from it then put them back on orrrrr?? orr.... you still do not have it wired right and the unit is still doing its job and shut things down.
also the solenoid pack you refer too.... that pack is main power disconnects... one of the items that triggers them to disconnect is the switch you refereed too.... the other one that can activate the solenoid to disconnect the box I referred to above. So something tells me your still not wired right so that box is doing its job.... orrr.... a solenoid is bad in there and keeping it shut off when all is fine.
with that in mind... is there not also a manual switch outside by those solenoid? I seem to recall two.. one in cab... and one outside.
Anyway; above scenarios have been discussed in here. Search for information on the solenoids. maybe some key words to search to find threads on this would be: solenoids, disconnect, main, "no power", "battery box"... some magic combination of these
best of luck. Hopefully this will get you started till folk way smarter than I am pop in to fill in more details.
