M1079 leaking air out the front bumper "Service" glad hand vent
coachgeo
3,547
North of Cincy OH
This one: N30252B on TM ...-24P, page 383, item no. 18.
Thanks a lot!
Christian
see https://www.haldex.com/globalassets/north-america/documents/valves/l00134.pdf it shows the repair kit number as well. search document for N30252B this will find you page number (19-82) all info there
which is Style is ours on that page (19-82) ... style one or style four?? let me know I'll add it to the speadsheet
btw it is 25bucks on popular auction site for new valve. I tend to get new valve and a repair kit.
coachgeo
3,547
North of Cincy OH
look at style two..... that looks interesting...... you get a shrader valve to air up the system externally......
coachgeo
3,547
North of Cincy OH
Don't forget to follow up with OEM style and size so I can add it to the spreadsheet
got a follow up elsewhere.. it is valve KN23010 3/8ths inch valve rebuild kit RN10CH
KN2320 still looks interesting with the refill schrader valve on it bu information does not confirm it is also 3/8 and if still considered Heavy Duty.
its been added to spreadsheet now
Mike Robo
Boston Mass
So I replaced the 3 front valves. You can get them at most air brake shops it just 2 way valves all 3 are the same.. Simmons in lawrence Ma. It solved the problem with the front glade hands leaking air. Now I have a new issue. After i pump the brakes 3-4 times the rear brakes lock up. If i push in the red service air knob it exhaust the air brake system and the wheels will free up until i use the brakes again. Anyone know which valve I should replace next. Thanks mike
