M1079 Power Question
Bowmanvolfire
Wichita Falls/Texas
Hello Forum:
We are hoping to pick up our M1079 on Tuesday. We have not had a chance to get into the weeds with it, but, have had a question that has come up. What provides the power to the box? Does the power come from the truck itself and is there an inverter that converts the power to 12 volt in the outlets that are on the walls.
Sorry for what might be a real basic question. If anyone can point us to M1079 specific manuals that would be appreciated as well.
Thank you.
John
BCVFD
Oxyacetylene
179
Stoneville, NC
The truck provides power for small lights in the box (emergency lights) and for the marker/clearance lights on the outside of the box. There is also an air circulation fan that is powered from the truck I think. The overhead fluorescent lights and the 120v outlets are wired into the breaker panel, which is fed from the power inlet on the outside of the box. The connection from the box to the rest of the truck is through a plug on the front of the box on the driver's side. There isn't a separate TM that I know of, but the TM does cover M1079 items. Those with running M1079's can help answer questions...I just have the van enclosure for now :)
Oxyacetylene
179
Stoneville, NC
Oxy:
Thanks for the reply. So just to clarify, the majority of the power for the box needs to come into the box from an outside power source, like a stand alone generator?
John
That is correct. There is a large inlet connector on the passenger side towards the bottom rear of the van enclosure. There's actually an inlet and an outlet so the van enclosure could be daisy chained with others or other equipment. It's a large cannon style plug that is expensive to buy unless you can find a deal. The breaker panel inside is a 3-phase panel, since a lot of (most?) military generators output 3-phase power. I think the heat/AC unit that is made to mount in the front is 3-phase also.
Bowmanvolfire
Wichita Falls/Texas
Oxy:
We have a military diesel generator (two soldier lift size) hopefully that will work to power up the box. Otherwise we may have some rewiring to do.
I hope some folks that have the M1079 will chime in with what they did to put power on the box.
Thanks again for the reply.
John
