- 5,564
- 2,829
- 113
- Metairie/La (N'awlins)
Just acquired a Water Buffalo from TimNTrucks and in the process of fixing her up. I estimate she is from the mid 60's-70's. No data plate but Id her from the tm as the A1. Single air line, single wheel cyls, and I have a plate over the water pipes inbetween the bread boxes.
1. Are the bread boxes on the front for the water valves bolted on?
Mine are welded to the water tank cradle frame that sits on top of the trailer frame. Not sure if a field fix or mod down the road. I can't seem to find anything in the tm. I have found the newer M149 has bolt on boxes. If you have actual pics of a M107 bread box, Could you share?
2. Any color pics of any any variant of the MERDC camo on a m107?
