M1081 Dash Light Doesn't Work
Phoenix77
543
Greenville, NC
I have a 1994 M1081 that works great, though the illumination for the gauges on the dash doesn't work.
Yes, I have turn the illumination dimmer all the way up, and no, this is not for the warning indicators, it is for the analog gauges.
Any idea where to find the bulb in the dash and where to get a replacement?
Thanks.
B-Dog
288
Denver, CO
Thanks.
Each device has it's own LED so if none of them are working, it's likely a main power/ground disconnect. 12v power comes from the light switch, through the dimmer and then jumpers from 1 led to the next through a couple dozen LEDs all wired in parallel, wire 1908 (+12v).
Same is true for ground, wire 3020 (gnd).
With the lights on, check to make sure you have 12v power at the light switch (pin B) or dimmer on wire 1542, same thing, just check whichever is easier to access. Then check the output of the dimmer switch, wire
Ronmar
7,442
Port angeles wa
There are actually 2 dimmers. One is part of the 3 lever switch(lower left lever), then it feeds the rotary dimmer. The rotary dimmer is probably bad. You can bypass it easy enough, just unplug it and put a jumper in the plug to test...
Mine was dead, I haven't replaced it yet and have just been using the dimmer in the main light switch as I plan on re-configuring the light switch control...
