M1088 camper conversion
ckouba
1,992
Oregon
Not trying to outsource it... Just know it's going to be a lot of work. Looking forward to having it done.
chucky
19,296
TN .
Been doing a lot of sanding and prep for glassing in the shower. Only real visible change is having the shower cubby built and installed:
Hope to get along with that project starting next weekend. First a coat or two for sealing up the wood so it won't soak up from the glass, then glass and resin for waterproofness, followed by fairing compound, a LOT of sanding, and the gelcoat. I know this will be a massive amount of work, but I am hoping it will be worth the effort in the end. I wasn't going to have a shower smaller than the available space, and no one made a ready-fit option in the size I needed. Hence, make your own...
Happy Thanksgiving to all!
Once you have your walls up for the shower/bathroom you could shoot all the walls and floor with polyurethane couple coats for a lot less work! and look at Formica brand and Wilsonart have so many cool finishes from metal to any color comes in 5x12 sheets just have someone with a big table saw set up to cut the sheet to dims you need easier to glue and install and alot lighter plus fully waterproof .
hike
—realizing each day
931
Texas Hill Country
You'd still need to at least fiberglass or epoxy the shower pan—
ckouba
1,992
Oregon
I am committed to this path. The reason why is that I don't want seams. The glass will lay up without a corner seam to seal and then flex and leak later on. I know other methods have been used and work just fine, but this is the path I have chosen and am OK with it. It will be a bit of work on the front end but I think the end result and peace of mind will be worth it.
At this point, the corners have been filleted and it would be work to reverse the process anyway.
chucky
19,296
TN .
I used ADVANTEC strips stacked to make the tub base then sprayed bedliner over that then tiled my shower base . On the first page of my build are some pics of the shower from start thru tiled maybe it will help ya !
ckouba
1,992
Oregon
Got sidetracked with another project: need over cab storage for a large inflatable boat we picked up. Building a roof rack combined with windshield protection and aux light mount. It includes a roof mounted hoist for lifting the boat (or whatever).
Boat:
Rack base:
Access ladder:
Start of windshield protection and light mount:
Without a bender, I purchased mandrel bends and will be splicing things together.
ckouba
1,992
Oregon
It will be skinned and used as the boathouse. I'd prefer to not have the boat out and exposed to 70 MPH road debris or 2 MPH tree branches. I am thinking of thin plywood, skinned with fiberglass and then faired in to smooth it out. Yes, that'll be some work, but I think that's the most appropriate option. I am open to other suggestions though and not committed to anything presently.
The "aero" part will tilt forward to accommodate the loading and unloading using the crane. It's ending up way more complex than I wanted to make it, but it also needs to perform the function.
There's enough room up there that it could be an in-law bunk.
Keith Knight
2,165
Wauchula, FL
Fiberglass would be the way to go but will take a lot of work.
FYI ( for your information) I purchased one of these to measure the wind speed above the cab. I needed to know what it was before I committed to installing the mini splits out side unit on the front of the habitat above the cab. With the fan blowing forward, the manual said a maximum wind of 10 mph.
So with my with driving 60-65 and me riding between the tire and air intake. I held the wind meter up and the max wind speed was 7 mph. The wind must hit the front of the cab and then basically go straight up over the habitat.
ckouba
1,992
Oregon
So with my with [wife?] driving 60-65 and me riding between the tire and air intake. I held the wind meter up and the max wind speed was 7 mph.
Wow!! That is a voracious thirst for knowledge! Not sure I'd have been that curious.
coachgeo
3,546
North of Cincy OH
have thought of a boat too. ... or better said..... dreamed. If did would lean too micro Jet boat so could scream across a water crossing to affix winch lines on other side in case things go bad in the crossing orrrrr.. bank on exit side is questionable.
ckouba
1,992
Oregon
I give you the world's most complicated roof rack/mobile boathouse, or at least the skeleton's proof of concept- it works!:
Boat loading cycle fully completed. Obviously, plenty of work still to do- put in a floor, skin it up, wire it up, etc... and I also have additional actuators to open it further. The good news is that it fulfills its intended purpose- it can load and unload the boat.
ckouba
1,992
Oregon
Making progress, I am pretty pleased with it so far:
The box corners are still raw glass. They will eventually end up getting faired out and shaped a little better, but for now they fill the purpose. I will also need to trim up the edges and massage one or two places, but overall I am happy enough with them. Once the weather warms up, I can take care of that. All I care about right now is the ability to get the box space closed up.
In addition, the interior shower got a good coat of resin on its wood and then at least two layers of glass throughout the whole thing, with 3+ on the floor and throne sections. That was pretty much the easy part- the real work is in the sanding and finish work still to come. I hope to plow through a bunch of that this week but time will tell.
Chris
ckouba
1,992
Oregon
Congrats Keith! If you head to the NW, drop a line and if you're in the SW in Apr/May, let me know where. Would love to check out your rig.
Keith Knight
2,165
Wauchula, FL
We already purchased tickets for overland west in flag staff. Also applied for the DIY part of the show.
is that where you’re headed?
We won’t get to the north west this summer but will be there as we head up to Alaska next summer.
