M109 Hercules Injection Pump Wide Open on Start Need cleaning recommendation.
welldigger
Benton LA
I forget the correct name for that clip but they sell similar type clips in the hardware section of home depot, tractor supply, lowes. Usually with the nuts and bolts.
1,189
Hairpin?
welldigger
Benton LA
Hitch pin clip. I believe I remember my local home depot having one small enough to work. It's been a while since I have looked.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Its like a hair pin, only both sides are curved. The hair pin only has one side curved and one side flat.
It looks a lot like the "parking brake retaining clip" images I found.
kinghomes
Huntsville/Alabama
M109 with Hercules Multi Fuel Engine Fuel Controll Assembly
Bellow is a re-post I posted in wrong section. I am reposting it here for background. But my current question is bellow
I lost the small stainless steel retaining clip for my M109 465-1 Hercules injection pump. I dissembled and removed the fuel control dowel and lever arm to clean.
Unfortunately, I did not note the position of the dowel in relationship to the lever arm. The assembly allows 360 degree assembly. Best I can tell from a picture, the control arm goes straight down and the small pin that fits into the end of the fuel control rod assembly should be at its lowest (down position) like the control arm.
I found a picture but it lack the resolution needed.
I have now installed the fuel control Assembly but I don't know how to know if I got it right. As this assembly is part of the shut off, I am afraid I could have a runaway motor if it starts. The assembly went in all the way and it seems to have the correct range of motion. If memory serves me, the fuel control control arm will travel freely from about 120 deg to 240 deg. Any ideas or insight?
Philip
gimpyrobb
27,787
778
Cincy Ohio
Leave the cover off and have someone start it up. You can stand right there and shut it off if there is any issues. If the lever doesn't shut it off, open the fuel bleeder on the top of the filters.
1,189
I moved you other thread to the correct forum a few days ago.
You have started 3 threads on this issue.
Do not post more than one thread on a topic.
I've merged all 3 here. Simply continue on this thread from now on.
1,189
Just looked and I see you actually started a 4 th post (the first on for this issue) and I will now merge it here too.
It helps when people know the full story(in one thread).
Also noticed your first post was in the 5 ton forums.
Pay attention to where you place your threads/posts.
Floridianson
2,522
Interlachen Fl.
When you get the assembely looking like this. Then pull the arm back to like the 4 oclock pisition or close to it and the pin will go into the collor. The collor is sitting in the shut down pisition as there is nothing holding it up. So pin at 9 oclock pisition and leaver installed on control shaft 87*. Put it in the head and move the leaver to the rear and it should drop in. If you have trouble just move the leaver to the 4 oclock pisition and look at the pin first. It should be horizontal going in because the collor slot should be horizontal just sitting on the bottom of the head. Guess that would be another thing to check before install of the control assembely but I have never had a problem with the control collor sticking in the up pisition when changing out the heads.
kinghomes
Huntsville/Alabama
Thanks for the help Floridianson. I assembled and fired the puppy right up. Before starting I drained a little fuel from the tank and also drained the filters trying to rid some water, but I did not see much. The truck had not been started in at least five years. After starting the air quickly built up and I drove the truck 1500' to my shop. But, upon approaching my shop she started to stall. The tank only had about two inches in it. Also, when I first started the motor for about 10 seconds I had left the filter bleed screw loose. So I likely sucked some air, water and/or bad fuel. Thanks for all of the help.
