M109 restoration
fpchief
225
South Alabama
I am inthe middle of a resto also. Does anyone know if the sheet metal flooring is welded all the way around on the outside? I have all the wood up and cut each bolt from above and knocked them out. The sheetmetal is the next challenge. I am thinking I will have to grind all the way around. Btw, pink PFD is my knee cushion!!!
Sent from my SM-G955U using Tapatalk
peashooter
207
Hanover, minnesota
On my 109 the sheet metal floor is stitch welded to each and every crossmember in addition to the sides. I ended up keeping my sheet metal floor and painted it with POR15
fpchief
225
South Alabama
On my 109 the sheet metal floor is stitch welded to each and every crossmember besides in addition to the sides. I ended up keeping my sheet metal floor and painted it with POR15
Gotcha. I wish I had that luxury. Mine is too bad. Thanks for the reply!!
USAFNB
59
Xenia, Ohio
@fpchief - Second on the stitch welds... could you cut out bad and stitch in new panels? I ended up doing that and then using POR15 to seal the panels...it seemed to work well. My box is getting removed eventually to make a shop at my property and I will replace it with a drop side bed. hope your restoration goes well!
Nick
fpchief
225
South Alabama
Nick
I had bad rust areas over the entire floor so I went into it figuring on an entire cutout. I just got finished removing all of the floor. A air hammer worked really good on the stitch welds. Will clean it up with a grinder tomorrow and treat the crossmembers. Gonna be sore tomorrow.
rustystud
3,374
Woodinville, Washington
Looking good !
USAFNB
59
Xenia, Ohio
Finished the wiper mod today, I borrowed this idea from another SS member. I used
Anco 4763 Wiper Arm Adapter and took off the military hook end. The Anco adapter for right over the factory arm and I used a machine screw to secure in place like the
military end did. Super excited to get this on my truck, as well as my other 2.5 and 5 ton truck. Adapter was a little pricey at $8 but worth it. Super painless mod.
USAFNB
59
Xenia, Ohio
Finished painting for the winter...it's hitting -20s here in Ohio and then warming up to 40. Obviously this state has lost its mind. Truck turned out pretty good, I will still need a 2nd coat before I call it done. For now I am collecting up new axle seals, rubber brake lines and other parts for a full drive train service at first thaw.
I've also decided to swap on a hard top.
cattlerepairman
3,501
NORTH (Canada)
How did you do the hard top swap? Two burly men and lots of grunting or front loader help? Did you assemble it on the truck or put the whole thing on in one go?
