M109 Wiring
Sundance
Cincinnati, Ohio
Does anyone know if the 115 volt disconnect box inside the van is wired to the external plug with both pins hot and the shell grounded or set up for one pin hot and one pin common? Can't find a diagrahm and haven't traced the circuits yet. Site searches don't seem to address this question. :|
Ferroequinologist
Resident railroad expert
724
Liberty Hill, SC
One pin is hot and the other is neutral. The body is not the neutral, AC circuits don't like neutral through a metal frame or box. Could cause a nasty shock. Box is usually grounded by a cable and grounding rod connected to the outside rear pass side of the box (at least both 109s I had had a stud and wingnut there marked 'ground'.
Sundance
Cincinnati, Ohio
Thanks for the foldout info. What has me confused is that the switch box says 240 volt and there are 2 fuses rather than one. The foldout just shows one fuse. The rest of the diagrahm matches as I have 4 circuit breakers and 2 outlet strips with 3 prong receptacles.
