M1093 wheels
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
I have a 1093 and a 1078. Will these wheels from GP fit?
No.
Those are mrap 330mm hub pilot
The type below will fit that is nearly identical to what you posted. . Notice the oversized lug at the ctis. Also the tapered lug holes. They have only ever sold 1 on govplanet though. Part # AS-18280
abfisher1798
87
Blythe, California
No.
Thanks. You spared me from another remorseful govplanet purchase.
Now all I need is to track down a seller. If you know of anyone, I’m interested.
Thanks again!
simp5782
9,369
Mason, TN
the XZLs in the listing you originally posted are xzl plus tires. Know that those are new with alot less tread depth new than a standard XZL
simp5782
9,369
Mason, TN
I have these on hand. Originally installed on the IVMMD MRAP.
If I change out the tires, are these wheels compatible?
No. Only 2 MRAPs use budd pattern. Caiman and MAxxPro Plus. All others use 330mm hub pilot. This is much larger than civilian 285mm hub pilot found on semis
And the vmmd is a husky not an mrap
