Good day All, I am new to the group, having just acquired a 1986 M1097. I've been working though a few bugs that it had before I could take it out on the road, but there is one that has me stumped because I dont understand the system well enough. It has 2 fresh (fully charged) batteries and a 200 amp dual voltage generator, a new voltage regulator and I believe all the wiring connected up correctly. My issue seems to be that I would have expected there to be 24 volts on the ignition/sense wire to excite the field and activate the regulator. Ive traced the wire back to the PCB (that seems like some sort of magic box) and I do not see any continuity through the box with the power turned off, but I expect that is because it only make contact when a relay is latched inside the box when powered up. I just don't see what I'm doing wrong and wondered if I could run a hot wire from the ignition circuit directly to the Voltage regulator sense to see it charge, or if doing that would blow up the (very expensive) PCB in the process. Any help would be appreciated as I'm at a loss!
