M1097A2 stop light issue
Gregory.cox3
North Carolina
Hello,
as you can tell by the title I’m having issues with my humvee stop lights. The blinkers and four way works but the brake lights do not come on. I’ve tried everything from changing the bulbs, changing out the entire light, changing the light switch, and changing the brake switch.I’m thinking it’s either the solid state flasher, the turn signal switch or there may be issues with The wiring. Any ideas?
NDT
7,505
Camp Wood/LC, TX
I would focus on the brake light switch. It causes headaches. The report that your 4 ways works rules out the bulb filaments, lamp grounds. You should have the dual brake light switch. Are you sure it is connected correctly? Is the linkage set up right? Put your ohmmeter on the switch and see if it changes state when you press on the brake.
Gregory.cox3
North Carolina
I’ll give it a try. I’m sure I got the brake switch correctly adjusted but I’ll take another look at it and see how it goes
20,787
Another thing to do if you don't have a helper is a small jumper wire. Jump it from one pin to the other on the stop light switch. If the brake lights come on, then the problem is in the adjustment or the maybe the wiring.
papakb
1,196
San Jose, Ca
This should be moved to the HMMWV Forum.
The switch and linkage AM General used came off of the M151 where it was also a crappy design. The incandescent lamps draw so much current that over time the switch contacts arc away leaving you without brake lights with everything else working. Sound familiar?
The pedal linkage has no free travel adjustment in it so your stuck trying to adjust the switch position where the lights come on without standing the truck up on it's nose. My solution was to install a waterproof, normally closed switch that turns the lights on as soon as the pedal lever comes off the stop.
Adding LED lights removes the current draw and keeps the new switch alive longer.
