M1097r1 need accessory belts
377
Owatonna, MN
hello! We are replacing engine belts on our m1097r1 equipped with the 3 belt 200amp generator. This is a 6.5 diesel with 3spd model. From what we can tell the 3 belts are the same but the one for the power steering is smaller. Any help on cross referencing the 3 larger belts and 1 smaller belt would be appreciated. Thank you.
Mogman
8,277
Papalote, TX
It would probably be better to buy a full set of alternator belts from one of the trusted dealers, it is next to impossible to get a matched set any other way.
Unless you live in a large city where you can go from one auto parts dealer to another of the same name trying to get three belts with the same build date, writing down the dates until you find three identical then backtracking and buying them.
They are just not that expensive...
377
Owatonna, MN
We have a Napa distribution center in town. If anyone has the cross reference numbers it would be appreciated as I’m hoping to wrap this project up this weekend if possible.
Mogman
8,277
Papalote, TX
Maybe this will help
377
Owatonna, MN
This helped!! Thank you!
