m1098 air valve.
man
Dandridge, TN
Hello folks! Been digging thru the TMs and posts to no avail. I have a 1098 with an odd air leak. Air pressure on both gauges is 120. After driving it tho, a loud air leak begins from a valve with an external rubber diaphragm which is located behind the front air tank. The front brakes then drag and sometimes lock up. What is this valve and why would it be leaking? It seems to be performing as intended due to the external diaphragm but it's never done this before. Help??
