M109A3 RVs? Who has one?
jesusgatos
on the road - in CA right now
yellobroc, here's your link modified from the old site... (got to be quick to capture the URL before it converts to an error page.. :) )
I've been getting a lot of dead links. How do you modify them to work?
You may want to consider a outside wood burner. There is some great wood gasification stoves that will boil water as quick as a JET BOIL system using sticks you find on the ground. They are great when camping. You can build you own using a few cans.
I've been thinking about wood stoves and wondering whether something could be made safe to use in an RV. Haven't started looking into it very seriously yet though.
tamangel
19
Nor Cal Coast
JesusGatos, links from the old forum won't work w/o modification..
if you have an old link, remove the following characters from the link's URL wherever they appear
amp;
(both letters and semi-colon as shown) don't put anything in its place..
Then take the WWW out of the link and replace with the word
old
it should then work..
Mike
rmgill
14
Decatur, Ga
I posted this 2 or so years ago. Still pretty darn cool.
The Aussies had IH make them what they call ACCO's. They're the Aussie Version of a 2.5 ton and 5 ton truck depending on the setup and they're cab over vs long nose like ours, but otherwise they're pretty much the same thing (minus different details like mid-ship winches and such). But a Deuce owner would look at one and know what he was looking at.
Anyhow, this chap named Rob Gray made an ACCO 6x6 into a bush camper. Lots of interesting engineering and ideas. His diary of the construction is at http://www.robgray.com/index_files/index_chronicles.php
n2ojunkie
clio, mi
Here are some of mine. Its not done but I have used it this last fall for deer season and stayed in it for 2 weeks with no problems. I have a 12k btu furnace that I took out of a rv and just about everything else thats "rv" came out of one. I have less than $500 in parts into it right now.
Things I have planed for this spring are a 32x32 shower in the front left hand side of the box. and a set of fold up bunk beds across from the counter. I want fold up ones because I still haul stuff in the back when needed. I also have plans to but a folding deck off the back, I want it the same size as the back of the box. I'll put a 12v winch mounted on the roof to lift it up into place when Im moving. Its kinda cold here right now so just about everything is on hold till it warms up. I had more pics of it when I was using it, I had a futon in it to sleep on, but I cant find them on this computer right now.
dinger65
cumming ga
Vinny, go to SEARCH and put in ZOUT. We are aprox 1/2 way done with our conversions and he has posted a lot of pics as the work was being done. It's a long thread.
n2ojunkie
clio, mi
Yes it is, I have a 30 gal tank that I sit under the truck. The hose comes out right above the fuel tank. But next year when I have the shower in I think i'll just run the shower hose down to a hole in the ground :roll: . I picked the truck up at the end of sept. and did as much as I could untill it was time to go. I also have a 13 gal, propane tank mounted where the spare tire and pioneer kit was at.
Clay James
Reno/NV
My M109A3 camper project. At the point where the inside panels and floor are out. That sub-floor was a nightmare to get out. Only have till the 14th of next month to get it ready for a beach camping trip with friends.
SCSG-G4
PSVB 3003
5,403
3,509
Lexington, South Carolina
My 109's are not going to be RV's. They both will be pantry's for the MKT. One is already done (see the thread "A different kind of M109 conversion") and I hope to start on the second one this winter. Main difference will be that the second one will have a freezer and a horizontal refrigerator instead of two horizontal refrigerators. The M36 will carry the bunkhouse.
