M1101 Light Bulbs
Cook4794
North Dakota
Just won a GovPlanet auction. My trailer is a 2009 Schutt M1101. I've been trying to find if it has LED or incan\6descent bulbs that i'll have to switch over to 12 volt.
My question is...
I have a 24 to 12 volt conversion harness for my m101a3.
I'm guessing, If my trailer has 24V bubls it will not work with my conversion harness.
My contract ID is W56HZV-08-D-0107, But I'm not sure where I can find the specs regarding the trailer or if its even possible? I have searched on the forums and I believe i'll need a 1167 and a 63...I have the page saved in my bookmarks. I'll have to stop by a wal-mart on the way to pick up the trailer and get the correct bulbs if they are not all LED.
Is there a way I can look up my contract ID and find out if all my bulbs are LED and I'll be good to go?
Gunzy
66
Roy, Utah
Most of the M1101/1102 have LED marker lites which are 12/24 volt but the tail lamps are usually not LED so you will need to change those bulbs. 12 volts will run them but they will be very dim.
Cook4794
North Dakota
AH, Roger that. I'll be driving during the day so it should be okay until I get to a wal-mart to get the right bulbs.
Daybreak
2 Star Admiral
770
Va
Howdy,
I see its a 2009 model. It has LED lights.
It was after 2006 when they were changed to using the LED lights. My trailer was delivered 10/06 and has all incandescent.
This is my trailer;
All the bulbs are standard incandescent. So swap out the bulbs for the 12v counterparts for a brighter safer day.
PU-798A Unit = Mep-803a with a M1102 trailer
Rear brake, turn light bulbs #1683 24v bulbs swapped to #1156 12v bulbs
Marker lights all round #1251 24v bulbs swapped to #97 12v bulbs
Trailer plug =cut off mil end, cheap 7-way plug attached.
Cook4794
North Dakota
Update!My M1101 is a 2009, it has all led side markers but the tailights are incandescent. I switched them out with LED replacement bulbs and it
texastrapper
Pinehurst Texas
Marker LED Light on ebay
10X White 1156 BA15S 22-SMD LED Light bulb Tail Turn Signal Backup RV Camper 12V
Tail LED Lights on ebay
4x Piece Lot M1101/M1102 Military Trailer Tail Light 12v LED Replacement Bulbs
Kevallarist
Clermont, Florida
I know this line is a bit old, but I am working on re-wiring my trailer now, I’ve done the military to 4 flat conversion.
My trailer is a 2009 Schutt m1101 but it doesn’t seem to have the bulbs like the others I’ve seen, the tail lights/blinkers are these one piece sets. Guessing in order to replace these with LED’s I’d have to get brand new housings?
