M1102 - Wiring Problems
emmado22
168
Mid Hudson Valley NY
Try this, I may of screwed up my wiring info in the Civy to Mil thread:
22-460 Right Turn Black with red tracer
22-461 Left Turn Red with white tracer
21 Marker Lites Red
90 Ground Black with red and white tracers
Report back. I bet this will fix it.
3dAngus
102
Perry, Ga.
Or, just do this.
1. No changing out of light bulbs.
2. No headache with wiring issues
3. Instant hookup whether by deuce or civilian tow
4. Bright and modern led lighting
5. Inexpensive
Remove the two reflectors on both sides.
Drill three holes, two for mounting screws, one for wiring
Install light, run wires through
Run harness and tie it down
Hook up wires.
Put grommet in third hole or fill with RTV to prevent wire abrasion.
Done!
About a 30 minute install.
porkysplace
1,496
mid- michigan
Or, just do this.
5. Inexpensive
Hook up wires.
Done!
Many states require ALL LIGHTS to work , if they are mounted they have to work .
3dAngus
102
Perry, Ga.
Then whats the purpose of magnetic lights, sold in every state in the nation through Harbor Freight or Northern Tool. Seems it would be illegal to sell them in those states as they are merely temporary with temp hookups. Not making an argument, I believe you, just think it is a bit insane for any state to ticket one who has a perfectly good set of lights on a trailer.
In my case, I'm safe, Georgia has some sanity left, and all lights work, they're just not all going to be hooked up at once.
Here's a digest of trailer lighting by state. It may not be complete which would support Porky's statement, but that doesn't mean he's wrong.
What is interesting about this is some trailers, in some states, don't need lights at all. Others, only need two, some one, and some need a license plate light with side markers. All states are different and some states differentiate requirements by weight with 3000 pounds or more being a critical point for requirements. Check your state for cursory requirements, but look further for finer detail in your own state requirements through your DMV.
http://drivinglaws.aaa.com/laws/trailer-lighting/
emmado22
168
We will get his trailer lights all figured out this week. Seems there are a few minor harness connections that need some TLC and then we can attack the "what wire does what" to get his new civy 7 wire plug going.
mac3497
Riverside Ca
I just got an 1102 and am going to buy the adapter (24v to civy 4 pin adapter on eBay). I know I need to change the bulbs out after the harness to make it work. Does anyone know the bulb numbers that I need? I will be running this behind a Chevy 1500. Also where can I get the bulbs...Autozone etc?
Thank you
