- 7,514
- 10,541
- 113
- Papalote, TX
If you look at this you will see the trans light wires come out of the same harness (see the loop around the wires that the arrows are pointing to, that is a harness sheath) as the brake switch, the TPS, and the ESS break out of.
The ESS and the TPS go into sheaths of there own but not the brake switch and MIL light (at least that is what it shows) so if you find the right spot on the harness you should see two sets of sheathed wires and 4 individual wires, two of which are going to the brake switch and the other two go to the MIL.
EDIT, if you follow the small harness back from the TPS it should take you right to that spot.
