M113 Chrysler Gasoline Engine 8763101 used in any other vehicles?
CombatJack
12
Texas
The Gasoline engine used in the early M113, PN 8763101..... was that used in any other applications?? I found one buried in the back of the shop, and wondering what all it goes to besides the early M113. Thanks!
NDT
6,486
Camp Wood/LC, TX
Not much else. Wehring has a XM474 carrier with that engine, and I have the remnants of a A/S32H-12 aircraft loader that had that engine as well. The engine was called 75M.
BravoMike
Denmark, Europe
I have one of these engines sitting in the original shippingcontainer. Engine has been rebuildt by Danish Army and not used since.
Question : can I find a automatictransmission and converter + starter that will fit this engine so I can use it in a car or small truck ect?
Thank You
Bjarne
www.bakercompany.dk
dmetalmiki
2,028
London England
'Whack' it into a WW11 Jeep if you have one. It is amazing what (Tank) Engines end up in them.
We 'popped' this unit into one of ours...
No trouble at all going up hill...s
jimk
45
Syracuse, New York
Question : can I find a automatic transmission and converter + starter that will fit this engine so I can use it in a car or small truck ect?<cut>
Not sure what auto trans is needed or where you might locate one however a New Process Gear 540, 541, 542 manual (5 speed) would be an option with the correct flywheel (not same as auto flywheel). 2 types of manual trans flywheels were used in the V100. Each must match the crankshaft output flange. They are not interchangeable.
The commercial Dodge truck NPG 5xx series transmission might be another option. The spare I have has a small input spline and a long input shaft (for a crankshaft pilot bushing). The V100 is different. It has a large ball bearing pilot located in flywheel, a shorter input shaft (because shaft does not need to reach the crank, and a larger input shaft spline). The old Chrysler 354 big block flywheel has the correct M113 bolt pattern and 13" clutch. It and could be used with the associated commercial trans or perhaps adapted for a V100 trans (an insert would need to be fabricated for the ball bearing because the 354 flywheel has a really big hole in center of the flywheel). It used the long input shaft (for a pilot bushing in end of crankshaft). A small spline 13" clutch would need to be used w/ the commercial trans.
There may be other variations and options.
flywheel pictures in link below (I have all 3 flywheels).
https://www.steelsoldiers.com/showt...13-engine-in-Denmark&highlight=m75+crankshaft
