CombatJack
- 12
- 8
- Texas
Not sure what auto trans is needed or where you might locate one however a New Process Gear 540, 541, 542 manual (5 speed) would be an option with the correct flywheel (not same as auto flywheel). 2 types of manual trans flywheels were used in the V100. Each must match the crankshaft output flange. They are not interchangeable.I have one of these engines sitting in the original shippingcontainer. Engine has been rebuildt by Danish Army and not used since.
Question : can I find a automatic transmission and converter + starter that will fit this engine so I can use it in a car or small truck ect?<cut>
