- 7,535
- 10,580
- 113
- Papalote, TX
The code 12 tells you it is in diag mode, it will flash 12 three times, then if there are any codes it will flash each code three times then it will flash 12 one more time telling you that is all the stored codes, there can of course be more than one stored code, you obviously do not have any stored codes.Yeah.... I left it there for a while and then repeated the whole procedure from scratch and all I got was the 12 (three times)
If it were me I would drive it with the TCM disconnected and if it did not exhibit any of the symptoms as before I would try swapping out the TCM as that is the most likely suspect.
