M1165A1 needs steering box - which one?
dma251
15
Arlington, Washington
I have an M1165A1 (I think it's a 2007) serial number 249812. Of course when I got it was missing some important parts, one of them being the steering box. I am aware that around this point the REV models got the Sheppard steering box, but I'm not sure if mine got that or not. Does anyone know how to determine what steering box it had?
gringeltaube
Staff Member
2,267
Montevideo/Uruguay
...... I am aware that around this point the REV models got the Sheppard steering box, but I'm not sure if mine got that or not.
NSN 2530-01-554-3441: Clearly, a Sheppard gear - according to your serial number...
Guyfang
22,177
Burgkunstadt, Germany
Also know, that below the Steering Gear, is the UOC. The UOC, Usable On Code, tells you what models can use that part. If you look up front in the TM, it explains what and how a UOC works, and then gives you a list, of what model truck has what UOC. Makes it easy.
spankybear
805
WA
Is it possible to install the old style box (Saginaw or Delphi or what ever it's called) on an ECV? Why did they change the box?
Coug
4,084
Olympia/WA
I don't know if they have the same bolt pattern, but if you changed out the box you'd also have to change out all of the steering linkage, as the two are different (so drag link, idler arm, pitman arm; possibly other parts)
The pictures of the two in the manual also appear to have different mounting bolt patterns, so if that's true that would make it a complete no-go from the start.
They changed the box because the heavy armored trucks variants were just too much weight for the old style box to handle.
rcamacho
818
Bainbridge Island Wa
Potentially however the frame bolt pattern is different. The frame would have to be reworked along with different steering linkage parts.
spankybear
805
WA
Or maybe an adapter plate... along with the linkages... I was just wondering.
