M116A3 hub only swap
Little Gus
Eastvale ,Ca
I have a M116A3 trailer and I do not want to do a full axel swap. I want to keep the original drop axel. What I would like to do is just swap the 8x6.5 hub to a 5x5 hub. Has anyone done this? Does anyone have a part number or info on where I could get this replacement hub?
Jeepadict
534
Round Mountain, NV
ETrailer and Croft would have it if it's available to be had. The hydraulic brake system on these was duplicated from boat trailers so we know all of that is easy.
Before you call them, rip one hub apart...get both bearings super clean so you can read the numbers. The bearing numbers will be the key to doing the hub swap.
Tho possible, I think you may find difficult to find a 5-lug with a center big enough for this axle. You might get lucky and your jeep wheels could be available in an 8-lug so they could match visually tho wouldn't be interchangeable.
Sent from my SM-G970U using Tapatalk
SgtMajHarper
574
Falcon, CO
I have one I kept original and haul my Mule on it.......I just gotta ask.........what do you carry on yours? I cut between the fenders to widen mine as otherwise I would have to drive up over one fender and it was scary enough just loading anyway. Cutting the fenders and making the space wider has saved a couple of my remaining 9 lives, but it's still spooky driving up. I can only imagine the neighborhood kids lining up with $$$ asking a for a turn to ride up and over both fenders on yours!
