M11XX series, remove snout/rebuild front
2mas-
Norway, Kr.Sand
Hi, i was wondering if it is possible to remove the forwarded snout on the m11xx series of the humvees to get a "flusher" look. It looks like the m11xx series have a longer radiator. So I guess there must be done som modifications to it
I want the latest generation humvee but I dont like the looks of the front on it and have been thinking if it is possible to set the "box" with the lights and the front bumber back to where it is "original" on the earlier humvees
TOBASH
3,474
Brooklyn, NY
So you want to take a superior vehicle and make it inferior, for aesthetics?
Possible but expensive. Radiator and hood supports need to go.
Just buy a M998 and swap in a turbo engine. It will be faster.
Mogman
9,532
Papalote, TX
Normally I would wonder why anyone would want to go to a smaller radiator in a vehicle that has heating issues to begin with but with the temps soaring to 68F in July you probably will be OK, I would think you would need to change the stack and get the proper brackets.
I would gladly swap with you, logistics would be a bit of a problem.
When I bought my turbo GEP I was offered all the parts to swap to the 11xx front end, wish I had taken him up on it.
BTW I am with you on the looks.
BLK HMMWV
491
Pasadena California
At one point I planned on adding the extended nose parts to my truck and started acquiring them I have most of the big parts I'm not sure I'm ever going to get around to doing it now.
thoner7
193
NE TN
I’d be interested in seeing someone’s build if they did this. Curious if you could keep that big long radiator somehow. The standard size would seem to be enough for civilian use as the H1 were turbos and heavier. I think they used the same one in the alpha with enough cooling too.
Retiredwarhorses
4,171
Brentwood, Calif
You cannot keep an ECV radiator with the old style hood, the radiator has a 12in support extension that goes in place of the 4in extension, it’s physically impossible. I’ve done many Turbo drive train conversions that use the A0-A2 non-ECV cooling stack just as the H1 does.
GTUnit
153
CA
Do whatever makes you happy. I think its WAY easier to swap a hood and cooling stack then to swap a motor.
