GopherHill
- 1,304
- 93
- Thomaston, TX
That is a LARGE and useful piece of yard art. A fine looking truck also.
Yep...I know what your saying...but not this timeRemember, this isn't a restore, this is David cleaning things up a bit. I've seen his previous 10 ton project.
Yes sir, I will be installing an engine air brake that I picked up NOS still in the box for $250.00!! It help's out alot when shifting gear's while driving as it slows down the RPM's much faster so you can grab the next gear while shifting. You have to install heavier double valve spring's on the exhaust valve's so the valve will not float due to the excessive exhaust back pressure created which could result in breaking a valve. I will also have the injector's rebuilt while I'm in there with the valve cover's off.How far into the engine do you plan to go?
