- 18,636
- 6,331
- 113
T-111 is a generic term for rough cut 4x8cdx plywood that has dadoo cuts to simulate planks.
In the south and mid-west most T-111 is plantation pine. Here in the NW it's usually doug fir - much better than sapwood pine for longevity. Current code also calls for a minimum ground clearance of 12"-18", to minimize rotting issues, at 61" of ground clearance I think I'm safe.
I plan on mixing 2 gallons of stain with 1 gallon of linseed oil and roll and spray it till it won't absorb any more sealant. Also it will probably have to be touched up yrly.
While not the best solution, it is cost effective. I'm disabled and on fixed income, I can only do what I can afford. 1 day of work costs me 2 days in bed, that's why this project is taking soooooo long. The staining and sealing will have to wait till spring weather, it's noon - 33 degrees and last night's snow is still on the ground.
I've already been admiring your work and craftsmanship. Thanks for sharing it.
Now that you've also shared the challenges you face and the obstacle that you're overcoming to get this done, I'm even more amazed and awed.
Keep up the good work. Take care of yourself. And, we'll keep you and your project in our prayers.
Best regards,
John
