M135 Rims and 395 Tires???
devilman96
Boca Raton, FL
I am looking to run 395 85 20 on my truck, I had fully intended to buy 20" bead lock wheels but I am getting into a pinch for money with everything I am doing so I am eyeing M135 rims as a temporary fix up but I am worried about size, back space, etc.
395's require 20X10" rims..... M135 rims are 20X11" (please correct me if I am wrong)... So I am assuming that M135 rims will run the 395's on a Deuce... Can anyone confirm this please???
spicergear
26
Millerstown, PA
M135 and M34 are all the same width. They are the old single style with the center positioned to offset the wheel (can) outward to widen the stance a couple inches per side. It's definately NOT a good idea to put the 395's on them. Ah, yeah...and aside from the fact that you'll need some impressive equipment to compress the tire far enough to get the ring on. Best bet is to wait 'til money isn't as tight-
spicergear
26
Millerstown, PA
I *think* it's a 1250x20 XL that a few people have outfitted their trucks with. But, they're only around 40" tall. An 1100x20 will be about on the nut at 42" tall. Guys have run each of these in single and dual applications though in dual applications the question comes up about sidewall to sidewall clearance.
M1075
Oklahoma City
The best looking setup I have seen is Michelin XML 12.00R20 on the M135 rims. Look in the photo gallery/super single pics for this and other options. Most guys just go with 1100s
FSBruva
Marietta, GA
M135 (&M34) wheels are 1 inch wider than stock M35 (&M211) wheels. The M135 wheels are 8.5 inches wide. Hope this helps...
Matt
gringeltaube
Staff Member
2,267
Montevideo/Uruguay
readyman said:
I went thru this too, the M135 rims are the same size as a M35 rim. Maybe 7 1/2 inches wide.
Sorry to tell you Matt, but readyman has it right: 7.5 inches rim width.
The offset or backspace is 9.5" (M35 wheels are 10.5")
Gerhard
