M151 1964 Kaiser serial number - 9 digit?
Krempely
Simpson 5M9
22
Tennessee or BUST
Anyone have a 9 digit serial number on their 1964 (Feb '64) Kaiser M151. Serial number is located on the dash mounted (round rivets) data plate. The SN is 704######.
Also, the right front frame/engine rail has a Data plate/sticker that indicates the body was manufactured by Freuhauf (No dates). I haven't stripped the hood to find any hood numbers yet. No hood numbers anywhere; under hood, body, etc. Anyone have a suggestion for the right hood number/alpha (such as 2K####, 2M#### etc) in case I can't find it on the hood? Thanks!
Krempely
'43 MB
'52 GMC M135
'64 M151
'66 M35A2
'84 M1009
'87 M1008
Wolf.Dose
9
Boehl-Iggelheim, Germany
There should be a little sheet metal strip below the parking brake just below the transmission cover sheet metal were it is spot welded to the lower part of the body. This about 3 inch long and 1 inch wide sheet metal carrys the serial number. However, very often this piece is gone due to several depot maintanances (sand blasting).
Wolf
