fland 244
- 1
- 3
- Kingston NY
Installed mechanical fuel pump..Coil now gets hot, suggestions that have been done to cool the coil, now that no air is induced?
Steel Soldiers now has an offical calendar available, read more about it at: Steel Soldiers 2021 calendar
Installing a Mechanical pump has nothing to do with your coil. HmmmInstalled mechanical fuel pump..Coil now gets hot, suggestions that have been done to cool the coil, now that no air is induced?
electric fuel pump bad.. got a tj murry mechanical.. you pull existing air pump and install the murry pump.... problem is no more air calculation through distributor housing which houses the coil hence it gets how and messes with spark..then let housing cool down truck runs fineWere you having problems with it and that's why you changed the fuel pump?
Never heard of this ? How do A2 mutt's coils "cool down". I am still learning, so excuse my ignorance. Cheerselectric fuel pump bad.. got a tj murry mechanical.. you pull existing air pump and install the murry pump.... problem is no more air calculation through distributor housing which houses the coil hence it gets how and messes with spark..then let housing cool down truck runs fine
I would pull your coil out and see if there is fluid in the bottom of the distributor. Word of caution have gloves on because that fluid is caustic and these coils have a tendency to leak. I've been told the fluid in the coil helps to keep it cool. If you find liquid in the bottom of the distributor than you'll need a new coil.electric fuel pump bad.. got a tj murry mechanical.. you pull existing air pump and install the murry pump.... problem is no more air calculation through distributor housing which houses the coil hence it gets how and messes with spark..then let housing cool down truck runs fine
