135gmc
- 1
- 0
- St Paul/MN
Remember, these were designed for low octane military gasoline - not the stuff we have now. If there is ever any ethanol in your gas, it will clean out the system, and you might have some dirt in a jet. I usually wind up installing an in-line gas filter a few inches in front of the carb on any vehicle that uses a carb. Also take a look at your accelerator pump - if it isn't set right, or has a stuck check ball, starting out will be difficult.
