M172a1 trailer wheel cover plates
tommygun
springfield tn
I have a m172a1 trailer and need to know if there is any reason i should not weld the wheel cover plates in place. Would it interfear with removing the wheel/tire ? Trailer used on paved roads only so wheel travel not a problem. Plates just to heavy to put in and take off every time .
M813A1
OKC, Oklahoma
If you weld the plates you will restict the movement of the suspension and that will cause your Tires to rub the plates when the suspension moves up and down !!
NDT
5,920
Camp Wood/LC, TX
I had to change a inner dual on my M172A1 and I was able to do it without needing the overhead access. I have the same idea, those plates are heavy as heck.
tommygun
springfield tn
Ndt thanks for the reply about still being able to change tire with plates in place . I recently saw a m172a1 that sold on GL that had plates welded in place by the Army. I think i will try it but weld them where the welds can be cut if i need to remove them later.
