M211 Factory Heater Instilation
sb4668
Brookville Kansas
I was just given a factory heater for an m211 for my m211 from our local fire chief it came off an m211 they use to have. My question is where do I hook the coolent lines. I know the tranny lines are there and I didnt know if I should risk cutting off the amount of flow to it by putting a t in one of them. if somebody could tell me or give me an Idea where to hook them up on the motor i would greatly appricate it.
APM215
9
Bradford. ON. Canada.
one line ties in at the small coolant line at your water pump (the one that runs back along your valve cover) and the other goes in to a bung on the head between the valve cover and the manifold. I will try to get some pic's wen I get a chance.
butch atkins
Fountain Inn SC
TB 9-2855-40 ,INSTRUCTIONS FOR INSTALLATION OF HOT WATER HEATER KIT,for the G-749 is in the tech manual section under the RESOURCES tab on this site ,18 pgs and covers all you need to know,lots of pics and easy to follow directions .good luck on your project
