M220 points roter & condenser
shell shock
Hi guys; Just me again looking for more answers. Does anyone now the Napa parts numbers for the points roter & condenser for the 1956 302 GMC?? I've tryed two different sets from NAPA and none will fit. The distributor was robed of these parts, so I don't have any to compare them with. Thanks Dennis
M543A2
10
Warsaw, Indiana
Dennis:
I have Echlin part numbers: Points CS777A Condensor RR175 NAPA should be able to cross. The rotor I never had to replace. It is special, and I doubt NAPA can get it. I recommend a military truck parts dealer of your choice. You might try the site sponsor. I have not yet had the opportunity to deal with them, but they get favorable comments on this site. I can also give you others if you like; just ask.
shell shock
Marti
Thanks for the reply. I'll try calling Saturn Surplus tomorrow. Sure not having any luck with NAPA. Sure do appreciate all the help from you and all the other guys.
white135
Auburn, IN
Just FYI... I have the Delco crossed numbers for the points and condensor. No luck on the rotor anywhere other than memphis, although they look like a new production rotor...
Points: DR2236P
Condensor: DR70
APM215
9
Bradford. ON. Canada.
Older 350 Chev rotor and points worked fine in mine give that a try
_________________________
53 GMC M215 CDN DUMP
54 GMC M220 SHOP VAN
47 FORD 2.5 TON CARGO
CLARK 55AG LOADER
white135
Auburn, IN
The DR70 does not appear to be the correct number, as the one I tried did not work. It may have just been a bad condensor however, I wil attempt some more researh later this week. My old one seems to work fine, but now I'm intriqued as to the correct one, and I may have to find it.
Eric
