M322 Trailer Axle Flange Gasket Part Numbers
Steelreaper80
20
Indianapolis IN
My M322 trailer is starting to leak slightly around the axle flange gaskets. I figure it is time to re-pack the bearings. Does anyone know the part number for the gaskets and would Napa have them? It is a Terex trailer so I thought that they might. Thanks
simp5782
Feo, Fuerte y Formal
3,213
Memphis, TN
Standard trailer 5.5" bc
Stemco/napa 330-3009
Go ahead and make them oil bath and be done. As much as you are using it you will benefit from it. Trailers that sit often i would repack bearings
Steelreaper80
20
Indianapolis IN
I finally got around to replacing the gaskets. I did not pull the bearings, they still had a lot of grease in them so I just pumped some more grease in them with the gun and buttoned it back up with the new gaskets. The gaskets were a perfect fit......AND CHEAP. Thank you!
