M35 A1 Turn Signals
Elk1111
483
Las Cruces NM
Has anyone here ever installed turn signals on an A1. I’m getting ready to install a new wiring harness but the A1 harness doesn’t have turn signals.
NDT
6,182
Camp Wood/LC, TX
While you install the new harness, run a new wire from the steering column area to all four lamp-units. Obtain a flasher handle, harness, and module from a later model truck. Match up the 461 etc numbers.
Elk1111
483
Las Cruces NM
I’ll probably have to make a separate harness for just the turn signals. Any idea how or where to splice in the power for it?
Elk1111
483
Las Cruces NM
That should work. I might even be able to salvage some pieces from the old harness to make a signal harness. Thanks for the advice.
