M35-a3 can you make it a true 6 wheel drive?
greenjeepster
10
Southbury, CT
Keep in mind that if you put lockers in you greatly increased the probability that you will take it too far and stick it deep. Recovery bills are high when the wrecker can't get to the truck.
I am not even going to get back into the argument about the Cat and Allison Combo not really having enough torque to turn 6 wheels in a muddy situation... If you have more money than brains than have at it.
jwaller
19
Columbia, SC
how much would that cost, that sounds like an idea. then if i get in the mud i can lock the hubs and have true 6 whell drive right. any draw backs?
a pair of locking hubs would prob run you about a grand, welding might be about a hundred. then your out a set of gaskets. cheap mans lockers and there are no drawbacks. you can either have fully locked or 1 wheel drive like you have now.
area52
San Bernardino CA
Have you actually gotten stuck in the mud or just had it slip and slid some?
Step 1: air down - cost = free
Step 2: chains - cost = varies but not too bad ( maybe $300?)
Step 3: upgrade tires - cost = varies probably around $200 per tire
these are all cheaper and easier than lockers.
Jakob
Louisville, KY
What about this...
ARB front axle
Welded front-rear with lockouts
Locked rear-rear
Seems like it would keep all the street manners and not be CRAZY expensive (but not the cheapest either). You could take it from 2x6 to 6x6 or anywhere in between. Just an uneducated opinion.
mudguppy
15
duncan, sc
why would you go thru the dangerous and back-breaking trouble of pulling a third-member to weld the spiders and not put in a $485 locker?
you can't even get a Detroit locker for a Ford 9" for anywhere near $500... :roll:
jwaller
19
Columbia, SC
bc most of the ppl on this site have little to no money for things like lockers. $485 is a lot more than free. pulling the chunk isn't much work with the right tools either.
jesusgatos
on the road - in CA right now
i'm speaking in general terms [thumbzup]
As a very avid wheeler drive flanges are always preferred to lockouts in regards to strength.
While I agree with you, that locking hubs are USUALLY weaker than drive flanges, there's simply no reason why they couldn't be designed/manufactured to be just as strong as flanges. There's still obviously going to be more parts, and there's not much that can go wrong with drive flanges. But if Ouverson makes/sells them, I'd be willing to bet that they're comparable in strength to the stock drive flanges (at the very least, wouldn't be surprised to hear they're stronger).
mudguppy
15
duncan, sc
OEM hubs are much stronger than the stock flanges. the OEM 16spline hubs are the same hub used with the 2" 47spline alloy shaft - just change out the splined collar adapter, but same hub body. they also have alloy drive flanges to use with their alloy axle shafts. these can be used to simply replace stock flanges.
actually, my plan is to upgrade my axle shafts and in the rear, run stock flanges from the front to be the fusible link - when they strip out, put the OEM ones on.
mudguppy
15
duncan, sc
correct, if both components are close to the same strength & hardness. the OEM alloy axles are significantly stronger than the flanges.
emr
25
landing , new jersey
Im still chocking on that one word Uni Dog..... UGH.....:cool:.....many storys from a few different guys who did alot of mauverse in germany, all said same thing the german guys were there trucks were all that, well storys i got is the deuces and 5 tons ate em up in staying in the game and pulled alot out. simple works. Sure they are great trucks, but really.....ugh. all in fun please...I followed a big one up a dune in my F 350 and some ww2 jeeps follwed it all over the place too, funny how the uni guys think, I ran up behind him just to show it could be done then backed down, not to scratch my truck, and the guy said, gee u could not make it, well lucky for the trucks it was said way past that hill or I would have done K turns all over it, I am ready anytime any one else is ....Randy
