M35 Custom Shooting Platform
bbbang
Lebanon, Missouri
I am getting my M35 set up for some serious recreational/target shooting, I got my M64 cradle mounted on the M66 ring, and am now in the process of building a custom shooting platform for the cab. The platform uses existing bolt holes in the floor, and can be substitued back and forth for the passanger seat, in a few minutes. I am going to pick up a hard top this evening and am going to modify it for shooting. Chris
sermis
17
Temple, TX
CliffW said:
This may sound silly but the passenger seat folds down for that reason to stand on for shooting from the m66 ring.
You beat me to it. Fold the back down and stand on it.
m52a2
Jackson, Michigan, USA
many WWII trucks with hard tops had ring mounts. look up some photo's you will see a revers flange around the hard top opening to allow a canvas cover be tied over the opening in the hard top when the ring was not in use. Ed.
sermis
17
Temple, TX
I have an access on my hard top. I will try to get some new pic's posted. I know there were some pic when I was sand blasting the truck.
bbbang
Lebanon, Missouri
Hi: I do have the reinforcement plate riveted in to the truck. I am going to run a Ramo M2HB on the MK64 mount. I will also run an M60 on the ring with a different mount. I do know the passanger seat will fold down but was not happy with this set up, the hight was wrong for me and I didn't like the lack of foot room. This mount will be rock solid and safe, it has a toe stop in front and much more foot room and is at the perfect hight,(for me) to shoot. I also made it where it would quickly substitute it back and forth for the seat if I wished, or use it in multiple trucks. I picked up my hard top this evening. I am going to cut a hole and then bend pipe in a circle to weld around the edge of the hole (unless I get a better idea in the meantime). Should make a nice and safe hole, then I am thinking canvas and snaps around the pipe to cover the hole. Chris
ARMYMAN30YearsPlus
Parkville, MD
Very Nice that will be awesome what about getting a custom cushion made so it could also serve as a seat? Keep us updated on the progress this is a very interesting idea.
Any word on the source of that alternator yet?
