bigmech
- 0
- 16
- Potterville Mi 48813
I bought a m35 from G.L. at selfridge Mi. base. When I finally brought it home and opened the hood I found a rod had punched a hole in the side of the block. I found a engine and during the swap I found that tere is a bottle of alcohol at the bottom of the firewall on the driverside that has a line goin to the injection pump. I had thought it had given up the ghost because they had kept driving it with the fan that was pushed into the radiator.Hence over heating it and roaching the rod! Whats up with the alcohol injection ? The line from the bottle goes to the bottom of the pump, where the cold start line goes on the other engine being swapped into it. I need some ideas, am I missing something here?
