jimwc12
- 2
- 3
- manhattan il.
Question for the multifuel hive mind, I had to pull the hydraulic head to repair a stuck cutoff sleeve. My concern is this, to remove the hydraulic head i aligned the timing mark on the damper, and the white groove on the advance lined up also but i could not see the red tooth on the hydro head nor could i remove the hydro head. I had to turn the motor over well past correct timing, ( mark was nearly under the water pump) before i saw the red tooth and was able to pull the hydro head. The white tooth was still visible in the advance housing, but definitely not on mark. The truck ran pretty well before the pump issue, and has 4900 miles on it. should i be worried or is this somewhat common? TIA.
