M35 turn signal problem
Digger09
New Jersey
I had intermiiten problems with my blinkers and it was the connection of the rear wiring harness to the front harness. It s located on the frame rail between the rear of the cab and the front of the bed. Took a little while to figure that one out so its worth a shot.
dmetalmiki
2,035
London England
I agree with cbvet... if they flash at all the eloctronic unit is good. If by out of sequence you mean ALTERNATE brake side lide flash, then that's grounding. (earth)
JSBIRD69
19
El Paso, Colorado
I had a similar issue, that when I placed the turn signal switch in the left turn position, everything worked as designed.
However, when I placed the turn signal switch in the right turn position, the front lamps were correctly lit, but both rear lamps flashed together, as if they were in 4 way hazzard position.
I had pretty much narrowed it down to a bad turn signal switch, or bad fender mounted flasher unit.
Since it was easier for me to borrow a turn signal switch to test for bad parts, I swapped it out first and VIOLA! All my signal lamps operate as designed.
I found a good deal on a new turn signal switch on the E Place on Wednesday, and it was delivered on Saturday.
I installed it as soon as I got home from the Post Office, and it confirmed my earlier diagnosis.
HTH.
Jay
dabtl
Denton, Texas
Any time there is a problem with lights, start with the grounds. When you know you have good grounds the rest is easy.
AMDOOR
Danielsville, GA
24v bulbs
I found a source for 24v bulbs. I now buy 10 packs of bulbs for less than I was paying each. The website is 1000bulbs.com. Just search for the bulb number. I ordered a package of each bulb that I might encounter for my vehicles and trailers and put them into my "crash kit" for vehicle recovery.
My Crash Kit contains bulb numbers 1683, 632, 1251, 1829, and 313. Those cover my needs for bulbs, other than head lights.
You might as well add the 12v bulbs for your other vehicles to the order. As with many mail orders, shipping for one small order is more than the cost of a $2.00 package of bulbs.
Dale
APM215
9
Bradford. ON. Canada.
this might help.
To test your solid state blinker box.
Pin “A” to a light bulb which is grounded
Pin ”B” to a 24VDC source
Pin “C” to ground
When “B” is connected, the light should blink about 80 times minute
